Hello folks. Figured I'd share my recent experience with these rubber bumpers on the back of our sportsters/speedsters. I scanned the web until I finally stumbled upon a site where someone had generated a 3D CAD (stp) file of these things. The link is here:
Seadoo Speedster 150 Rubber Bumper PartNr. 204071739 by schiffer-soft
I downloaded this file and had them machined out of delrin. I was orginally going to get these 3D printed but I used a friend of a friend that worked at CNC shop and was able to get these on the house.
Please note that there a total of 3 of these bumpers. The two on the outside are held in by loose hardware composed of (2× each) 10mm nut and flat washer. This sucks because you either need two people to install them or painfully stretch your self to be able to catch the loose hardware so it doesn't fall in engine compartment. I did it by myself and I would have preferred to have another person. The center one is easy. It doesn't have loose hardware on inside.
To not drop hardware, I used a pair if needle nose vise grips pliers to lock onto nut inside engine compartment. I then had to stretch myself to be able to hold the the pliers and used torque wrench to loosen it all the. DONT DROP THE WASHER. The hardware is stainless and it's hard to fish out of the tight engine compartment.
Check it out and let me know if you have any questions.
Broken/worn out original
New ones
Two 10mm nuts and washers holding outside bumpers in place.
Tools needed. 10mm socket, vise grips, #5 torque wrench
After removal of old ones. Note how I used vise grips to hold nut during removal and install.
Picture of old center one. This is super easy as it doesn't have loose hardware in engine compartment. Just unscrew old one and install new one.
