les morgan
My wife was given a 95 GTS about 2 months ago. It had been sitting for
about 2 years without being used. We cleaned it up and filled it up with oil
and gas (adding marine stabil) and everything ran fine for about a month.
Now it will run great for about 1-15 minutes and then seems to go to about
1/2 throttle. If you let it idle for a little while it jumps out of the hole like
everything is all right but then drops down to 1/2 throttle again. I have
replaced all the grey fuel lines and added sea-foam to the fuel but the
problem persists. Any thoughts? And it seems like the longer you let it
sit or idle the longer it will run great.
Thanks
' Les
Thanks
' Les
