bogging in corners
DB3D
My 3d runs fine on the flat and straight but when I corner hard or in a lean over situation more so to the left it will bog to half throttle. I have cleaned the fuel filters on the fuel pump, ran injecter cleaner through it, cleaned the tank and made sure it has good fuel. The rave valves are turned all the way out I noticed, the ski has about 50hrs on it.. any ideas or help would be great...thanks
The 3d has a big pump... and it can bog the engine in a turn.
I would check the engine compression. If you are starting to get low... your HP will drop.
I might have THE answer. I will double check something and get back later. But it isn't a problem with the ski.
