I have two problems. One, I cannot figure out how to remove the existing Bilge pump. Secondly, I can't find an OEM replacement.
1) I tried to remove my bilge pump but can't figure out how. Do I turn the big "wing nut" looking assembly at the top? So far, that will only move about 5 degrees and doesn't seem to do anything.... I have read that you un-clip it from its base. I don't see where those clips are and how to unclip it. Anyone have a picture that would help explain how to remove it? Maybe it's just clogged?
2) The part number for the pump appears to be: 204471072. However, noone seems to have it in stock. Can anyone recommend a replacement pump and tell me how it would be mounted?
Thanks,
Brian
Thanks,
Brian
