100dollarbill
96 speedster with Rule 500 gph bilge pump. Does the pump have a one way check valve?
The pump works fine but the problem is if the outlet is below the water line water gushes in as fast as it was pumped out. Today I went to the boat and the engines were under water, up over the carbs. I had left the battery disconnected so it couldn't pump anything out.
Anyway, do I have a bad pump or can water flow both ways?
