Beeper........buzzer
Bills86e
Premium Member
Premium Member
No BEEPS
bad buzzer, commonly go out on olded ski's moisture deterioration
http://www.seadooforum.com/showthread.php?p=126920#post126920
The sensor/sender is located between the spark plugs and when the engine reaches
203-205 degrees, contacts/moves and grounds the wire to mpem, signaling the beeper.
Grounding the sensor wire should produce the beeper/buzz. Periodically check it, ignition on.
Seadooforum
You can obtain a year-model SHOP MANUAL and learn everything about your ski.
You can click on the link seadoowarehouse to veiw your skis parts and part numbers.
then at right top click "parts by year, then by Model, then Section, place a number
in box at left, scroll down to page bottom and click Add items to cart, and then the
parts numbers will appear! then click the Clear Cart button after you obtain the #
or you can order that part from our host! Your SHOP MANUAL will describe in detail
how to maintain any part or remove and replace any part on your ski.
NEW MEMBERS ARE ENCOURAGED TO JOIN AS PREMIUM MEMBERS SO AS
TO HAVE ACCESS TO THE FORUM LIBRARY SHOP MANUALS AND SUPPORT!
Please also to use the SEARCH function, as many subject questions have been already asked and answers many times!
Beeper/buzzer is inside the handlebar pad where it can easily be heard. The wires
are loomed down the center of the steering column then connect to the electrical
wireing harness. A DETENT TOOL is available from Radio Shack for pushing the pins
out of the plastic connector clip if you desire to pull the wires thru the column. Radio Shack Part # 274-223 for .093 pins.
Note
each wires orientation if you do that. Some people just connect a new beeper under
the sterring consul as a easy location. Hope this Helps! Bills86e
