Air filter housing removal on a 96 gsx 787 engine
JETSKILEE
How do you remove the air cleaner housing on a 96 gsx 787 i am putting on a oil pump block off and need to remove the cable to the carbs.
Remove the cover by sliding the tabs forward. There are 10 mm bolts under the cover inside to remove the air box, I believe on that model if memory serves me right.
Karl
