Ksengage719
Anyone have any websites for aftermarket parts for my 99 gtx limited 951cc
Honestly a 99 GTX limited is pretty maxed out from the factory. And being in a 3 seater it is never going to be like a 2 seater due to the weight. My opinion is to love it for what it is. It should not be slow at all and is the fastest two stroke 3 seater seadoo built.
Adding performance parts to a used 951 is a ticking time bomb.
I would suggest...
1. Making sure your fuel system and carbs are serviced and spotless.
2. Using the correct API-TC full synthetic oil.
3. Checking your impeller, wear ring and carbon seal.
Not a fan of the doninator. I like the interceptor in all my 2 strokes including 4 wheelers, 3 wheelers,skis, dirtbike, chainsaw, weed wacker and hedge trimmer. Never had a seizure or blow up in 10 plus years. Isnt dominatir the one that advertises low smoke? Just putting this out there but if you mix it at their recomendations of 100:1 its gonna be low smoke compared to mixing another oil at 50:1. But if you have had luck with it keep using it. I have never personally used it. When they came out with doninatir the bottle said on back in small print-for use in race engines that are rebuilt every year. I dont have much faith in oils that advertise that.
Your stock impeller is stainless and one of the best for the stock application.
Seadoo put the best on theirs from the factory unlike Kawasaki and Yamaha with their aluminum ones.
