JJinSC
Well again after sitting all winter (gas was treated). The mag carb accelerator nozzle is clogged again causing the bog from idle to speed. I did not change the charge lines when I changed the fuel line from the tempo lines years ago. Since I gotta take the air box off to blast the a-nozzle again, I plan on replacing everything from the a-pump to the carbs. What all do I need? What size line? All parts diagram do not show an inline check valve on the charge line, yet mine came from the factory with one. Do I need to put one back? If so, with what part?
Thanks in advance.
Thanks in advance.
