wakeboard33
I recently bought a used 99 XP Limited. Upon first ride the PWC is taking on water rather quickly. I checked for any hull leaks and that is not the problem, no water enters the hull when PWC is off and sitting in water. The PWC is taking on water rather quickly at idle and speed. The exhaust does not seem to be leaking either. I have removed the pump and bottom plates and nothing really seems suspect. At Idle it appears that the leak is pumping in water from the bottom. I have monitored closely and it is not apparent where it is coming from? I used the flush kit to see if I could fill the hull up at idle that way but no luck. Only fills up at idle or speed in the water. Yes the plugs are in.
