So I ignored my leaking jet pump long enough and the thrust bearing blew up. I am going to rebuild it soon, but have a question before i start buying stuff.
the impeller shaft is worn down in 2 spots(groves) where the oil seal makes contact, the possible the cause of my oil leak. Is this normal wear and tear or is this indicative of other problems? out of balance impeller, misaligned/bent drive shaft?
thanks
jesse
thanks
jesse
