SabrToothSqrl
Have a 1999 GTX LTD, rebuilt engine last summer, ran fine from then till now.
Put in a new impeller (factory) and wear ring last fall...
Won't break 6,200 RPM on the water (will on land).
Ran 58 MPH start of season, now around 52.
I pulled and cleaned the RAVEs.
I Pulled the water regulator from my other ski.
I replaced the air lines and check valve off the crank case (valve was letting air go both ways, one line was cracked open)
I replaced the entire fuel filter assembly
I took out and cleaned out the fuel selector switch.
I replaced all the fuel lines with new, minus the ones actually ON the carbs.
I have been bashing my head against the wall on this for almost 2 weeks now.
What's left to test / fix / change?!
The only thing I can think of is there are filters on the carbs right? If I pull the carbs, maybe I will find my answer? a seal, or a filter issue?
The engine seems to run fine, starts fine, just not 100% power and I am 800 RPM shy of where it should be...
Suggestions / Help / Padded wall?
thanks!
thanks!
