the part number for the neoprene pump seal is 293200024.
you can get them at Parker Yahama
http://www.parkeryamaha.com/seadooneoprenepumpseal293200024.aspx
or Impros
http://impros.com/store/index.php/p...sings/sea-doo-140mm-neoprene-pump-gasket.html
or Perry Performance Group...
The 1998 Speedster and challenger do have these seals... it is imperative to have the seal in place... number 2 cause for cavitation.
I recently found out that the foam seals supplied with the white Delrin SBT wear rings are small in outside diameter... So I did not use the SBT foam seals and used new OEM neoprene seals...
I also see that the SBT wear rings are much looser in the pump housing than the OEM wear rings. I understand compression holds them in place and have made a mark to see if they spin. Since I already have them I gave them a shot, we`ll see...
