does the fuse blow when you start it or once it starts?
someone had something similar a while back on a 951 and it turned out to be a piece of metal shaving off the starter gear had found its way onto the stator and shorted it out, causing the fuse to blow every time the engine was run. sounds like the replacement stator might be bad/shorted
