97' spx -grey lines?
kloock959
97' spx 787 motor. all carb settings are stock, fuel filters clean, jets clea, 155 psi on each cylinder. I can get on and ride all day below 1/2 throttle, as soon as you hold wot it will die out like loss of fuel, if you hold wot it will die out (not compleatly, boggs a bit) and then take off again, this will continue if held open. if I am to shut the ski off and sit for a few min. i can start back up and take off wot, running great for about 1/2 mile or so then back to same issue. Could this be caused by grey fuel line? Sorry for the long post.
Yeah. Big stainless doublem has gasket underneith that leaks. Tuned pipe-funnel pipe.
sounds good i'll double check that. wouldn't i get exhaust film around the gasket if it were leaking. does the selector plug up or deteriorate when they fail
well, checked stinger pipe no exhaust residue around any part. seems as though this ski has a plastic selector in it already. should i replace due to internal orings? seems to act the same when it is on main or res. Should I be going up in main jets. Haven't checked the rectifier yet, will do that when i get home.
replaced the fuel lines and selector, runs great. seems to be more the cause of my selector switch. thanks for the help
