MLars
Hi guys, most likely picking up a 97 Speedster for real cheap from a friend soon and just have a few questions about it.
1. I know I'm beating a dead horse here, but which oil should I use in the 717s; semi-synth or mineral oil?
2. The glass is in great condition but the plastic is really dull and faded. What's the best way to bring back the shine? Compound or heat gun?
3. The trailer bunk brackets are completely rusted and broken. What's the best way to lift the boat to replace them? I've seen some videos online of just using car jacks with plywood to do it, I would assume it's the same with this?
4. Both engines blow anywhere from 145 to 150 psi, but only the starboard engine runs well. The port engine fired then died after 2 seconds. My guess is it's either bad gas (been sitting for 3+ yrs) or a clogged filter. Either way I plan to siphon and drain the gas and oil, then replace all fuel and oil filters. What about the carb filters? These boats didn't have grey fuel lines so there wouldn't be gunk in there right? Do you recommend I replace the carb filters too? Do I have to take the carb off the engine to do it?
5. What's the oil and fuel line size? I know on the skis it's a mix of 1/4 and 5/16, what about the boats? I plan to replace all the oil lines while I'm in there doing the filters.
6. How should I wash the cover? It's the original one and in great condition besides some dirt all around the sides.
7. The grab handles are covered in mildew. What should I use to clean them or should I just paint them? What cleaner or paint?
8. This was a saltwater boat but seemed meticulously maintained; the steering cable is locked up so I know I will need to fix that. Anything else I should be aware of?
