Ok....I have a 97 xp that between half throttle and 3/4 throttle shuts down. Just like someone pulled the lanyard. Sometimes it fires rite back up and sometimes it spits and sputters for a bit before it will crank. If i jump a wave it shuts down. If i get On it hard from dead stop it shuts down. Up too 1/2 throttle runs fine. I have replaced all the fuel lines. I have put rebuild kits in both carbs including new needles and seats. Cleaned fuel filter and cleaned the fuel selector. Performed the fuel pressure test which holds fine. I usually cant get it too shut down unless its in the water. Both cylinders show 155 psi. New plugs do not help. Cleaned up the grounds in the electrical box. Coil tests fine on the multimeter. I am scratching my head..............what am i missing???? Please help, ineed input? When i have pulled the plugs they seem a little wet?
