That is for the accelerator pump and it has a little check ball in itif I remember correctly.
You shouldn't force anything into it. I would soak it overnight in some carb cleaner and try blowing it out with carb cleaner and compressed air the next day.
Finally, you should not be taking them out of the carb as they are pressed in and can be loose when you try to reinstall them.
