Shop Discount Sea-Doo Parts
97 GTX won’t go over 3500 rpm in water
Matt12995
Messages
11
Likes
0
Water Crafts
1997 sea-doo gtx
#1
I have a 1997 GTX that runs 1500 at idle on the trailer and 1100 in the water. It takes off fine but tops out at 3500 rpms. On the trailer it revs up fine. If I can catch a wake and get the ski out of the water it will take off and run fine. The ski has new carb, new fuel lines. I just had it in the shop to replace starter. The service guy said wear ring looked fine and compression was good. I have tried running it on normal fuel tank setting and on the reserve setting. No difference between them. I have also tried running it and pulling out the choke and it just cuts out. I wanted to see if there is anything that I can try before I take it back to repair shop. Thanks for any suggestions.
Messages
149
Likes
20
Location
CO
Water Crafts
95 XP720 +3mm Bore
95 GTX657x +1mm Bore
#2
When you say new carb what do you mean? Was the oem mikuni carb rebuilt? If so was it rebuilt with genuine mikuni parts?
Right out of the gate this sounds like a fueling issue which almost always a carb problem
mikidymac
Moderator
Staff member
Moderator
Messages
12,160
Likes
1,209
Location
California
Water Crafts
2003 GTI
2001 XP
1996 XP
1996 HX
1991 Superjet
2001 Superjet
#3
First your idle should be 3000 on the trailer and it should drop to 1500 in the water.
If the fuel system is good and pulling the choke doesn’t help I would check the RAVE valves. They need to be clean and some skis will do exactly as yours is if they aren’t the updated “slotted” valves.
Messages
454
Likes
50
Water Crafts
RXT. RXT IS SPEEDSTER 2006 REPAIR SEADOOS WEEKLY FOR CUSTOMERS
#4
Rpm way to low in the water and on trailer
It’s bogging down now due to a lack of fuel as the vacuum through carb is insufficient to draw fuel out of fuel chamber
Matt12995
Messages
11
Likes
0
Water Crafts
1997 sea-doo gtx
#5
The carburetor was replaced with a new one.
mikidymac
Moderator
Staff member
Moderator
Messages
12,160
Likes
1,209
Location
California
Water Crafts
2003 GTI
2001 XP
1996 XP
1996 HX
1991 Superjet
2001 Superjet
#6
Your ski has 2 carbs so I hope they replaced both and installed the correct jetting in it because all skis are not jetted the same.
GGuillot
Messages
893
Likes
133
Location
Alabama
Water Crafts
1997 GTX
1996 GSX
#7
Personally, I'd skip the shop from here on out. But since you paid money and it's not right, bring it back to them. They should know the idle should be set at 3k out the water. Ask them specifics about carb settings.
It's difficult to asess anything unless you tear into it and verify yourself.
Matt12995
Messages
11
Likes
0
Water Crafts
1997 sea-doo gtx
#8
I tried to adjust the low setting on the carb but it did not affect the rpms at all. I found on here the steps to set carb but not sure I did it right. I found and adjusted the screw with the T on it and nothing changed.
mikidymac
Moderator
Staff member
Moderator
Messages
12,160
Likes
1,209
Location
California
Water Crafts
2003 GTI
2001 XP
1996 XP
1996 HX
1991 Superjet
2001 Superjet
#9
You need to adjust the idle screw, not the Low Speed screws.
Messages
454
Likes
50
Water Crafts
#12
No you should have a small cut out for access
But removing airbox will give u a better idea where the adjustments are and can check the oil pump too
Install the flame arrester with out box on you can then set your idle and then check your oil pump setting in that order
Then reassemble air box on
Matt12995
Messages
11
Likes
0
Water Crafts
1997 sea-doo gtx
#13
Got it running 3000 rpms now. Will get it in water later this week to test. Thanks for the help.
Messages
454
Likes
50
Water Crafts
#14
Sure double check oil pump cam line lines up with line on casing
Messages
454
Likes
50
Water Crafts
#19
So it’s running very rich
You will need to adjust the cable you’ll need two 10 mm spanners
It’s the same as adjust a Bicycle brake cable
Picture below shows the opposite side of the cable from the pump
Undo the nuts and turn the one furthest away from the pump out and tighten the other
The two lines should line up
mikidymac
Moderator
Staff member
Moderator
Messages
12,160
Likes
1,209
Location
California
Water Crafts
2003 GTI
2001 XP
1996 XP
1996 HX
1991 Superjet
2001 Superjet
#22
You have something wrong with either the cable, the cable attachment or your idle is cranked up way too high. There should be no issue getting the oil pump lines together.
Messages
454
Likes
50
Water Crafts
#25
What did u set the low speed screws after you turned them ?
Check the routing of oil pump cable that nothing is rubbing on it and it’s in the cam groove correctly
Who installed the carbs ? Did the check the cable attachment etc was the same as one removed ? You normally can get at least 2 or 3 millimeters either side of the line with adjustment
SPONSORED LINKS
Usergroup
