Just replaced the wear ring on my ski, took it out for a test run, everything went well for about 5 minutes then the engine started to get a miss, on the way back to the dock it started running worse and then would only top out at 3390 RPM's
at first I thought it was the carbs (I have repaced fuel lines and rebuilt carbs a couple of months ago) When at idle it would only idle around 800 RPM like it was running on one cylinder, trying to giver it throttle it would only go to 3390 exactly 3 different times, I did a compression test, 150 on both cylinders. Batt voltage not running was 12.57 did not get a chance to ck it running yet. Any Ideas as where to start. Thanks for any input
