Starts and idles fine but on acceleration cuts out spits, backfires. Let off the throttle and it goes back to idling fine. With an inductive timing light I can see both cylinders firing fine at idle but cutting out on acceleration. Seems if you baby it you can get it to accelerate a little past idle but misses and runs bad. I have gone thru the fuel system and am sure it is fine (carbs, lines, selector). I feel the timing light test points to ignition. I have a manual coming but hope someone here can give me a clue or an idea what to try.
