My cousin bought this 1996 xp and ran great till first time of summer last year wouldnt start so he took it into the shop had a new starter put in then they said it had a knock from the crank bearings but wanted over 3k to fix it. so we ripped it apart have the whole engine apart and found no signs of any bad bearings or abnormal wear except on the pto side crank bearing seams a little rougher then the others but bearly. so kinda stuck with what to do know. did the shop just bs him for more work or did they mess up something in changing the starter out..we did find they did not put in the back starter bolt could that have made the "knocking sounds"? we want to replace the pto bearing but cant get the drive shaft gear off the crank is there a trick to it? any input will help
