So heres the story...
I have had this ski for two summers now.
I cleaned the carbs myself and replaced all filters, diaphragms, and etc.
Brand new starter
Brand new battery
Brand new fuel lines
Brand new fuel filter
Brand new Seadoo oil
Brand new Starter solenoid (last summer)
Brand new starter button (last summer)
Brand new Voltage Regulator
Brand new spark plugs
Heres the deal...
I had some problems with it last month and it would start right up perfectly and then when I got it o the water it would start and barely want to run. Basically it would start and idle fine but then bog down as I tried to get half throttle and then it would make it through half throttle to full throttle and go for a second and then bog down again and die. I Tried to adjust the carbs high and low jets to fix it but nothing. I tuned the carbs to factory now and then replaced the Voltage Regulator. When I got it back on the water after changing, It started for a second but no strong idle and then it wanted to go one time but then died. After trying to start a few more times it finally went into trying to start by itself. I had the key out and it sounded like the motor was trying to turn by itself. It kept making this noise almost like a consistent turning of the starter but I'm not sure. I then immediately unhooked he battery to stop it. When I tried to hook the battery back up, it wanted to jump start immediately when I touched the wire to the battery. I now have the battery unhooked and I have stopped at that.
Is it possible that the Voltage Regulator was wrong?
Or possible starter solenoid gone bad or grounding out?
Or possible starter button gone bad or jammed?
Or something else?
Please let me know.
Thanks for reading also!
Brand new starter
Brand new battery
Heres the deal...
Or something else?
Please let me know.
