96 GTX MAG side carb split case
mitchrp
I was working on my ski... as usual!!!.. and saw a split in the metal of the MAG side carb.
A couple of questions. 1st, is it okay to only purchase a MAG side carb only or do I need to purchase both MAG and PTO carb?
If a used carb is okay I would get a rebuild kit for both MAG and PTO carbs.
2nd. Would like recommendation on good place to purchase remanufactured carb.
Thanks for the help.
Can you post a pic of the problem?
The best place for a used carb is eBay. A new one will cost +$400.
Busted Carb
Tony
Here is a pic of the carb... as you can see I made matters worse trying to get a stuck bolt off the carb.
The PTO carb is fine and ready for rebuild.
I was hoping that I would be okay just purchasing a used carb and rebuilding or purchasing a remanufactured MAG carb.
Or is it even possible or feasible to just purchase the broken throttle body ?
Thanks for your help .. You have helped so many others on this forum, I am glad you gound time to help me !
BTW.. Ski is 96 GTX
Thanks again
If you buy the same model carb, the only issues are if it's fully operational and you can sink-up all the linkage. There is no reason that I know of to replace both of them unless it's cheaper to but a set. I wouldn't buy part of a carb under any circumstance.
That's just ugly. My worry would be the hunk that's missing. (and id it go into the engine)
You probably can't buy a rebuilt carb outright. Most rebuild shops dont' do that... and new is crazy expensive. If you can find just a body... that's fine, and you can transfer your parts into it.
Thanks
To all that helped ... THANKS !!
I was lucky enough to go on Ebay this morning and someone was selling a pair of carbs for my Seadoo. Picked em both up for 150.00. Attached a pic so you can see what I got !
so it was you who bought those......I was trying to buy them this morniong and it kept telling me that i was too late they were sold so i contacted the seller and he said i just missed them...hmmmmm small world ...those are the ones that said cleaned but not rebuilt right
Brock
Not sure if these are the ones you were bidding on ... bidding ended at 3:00 EST today. But the description is the similar.
Here we have a set of stock seadoo 787 stock carbs, Part removed from a 96 XP. carbs were just cleaned out, They were not rebuilt. Looked good inside except for needing cleaned. Ran the boat good. This is a bolt on and go set of carbs, the cleaning has already been done.
Anyway ... while I am sad you didn't get it .. I am happy that I won !!!
Mitch
