MC87SS
Hey everyone, been a while. I hate how life gets in the way of ski time.
Beginning of last year i bought a 96 GTX to replace one of my 95s, It ran good but as always needed some TLC. Did all the normal changing the fuel lines, cleaning the carbs, cleaned the rave valves, etc. Went out a few times last season and although it ran good i could never get it to rev over 6500 rpm. Labor day i was at the river and the driveshaft bearing went and water started flowing in so i put it on the trailer. A couple weeks later my son decided to take the 95 out while i was away and since he didn't know anything about them managed to destroy the wear ring and overheat it melting the oil line and exhaust coupling. Thats a story for another time.
Over the winter i got new rave bellows and springs, a new water regulator and driveshaft bearing. Last week i finally got time to work on them. Installed everything and went to the lake for a test run. The 96 ran great but still maxed out at 6500 rpm.
What should i try next to get it into the 6800 - 6900 range?
Second problem happened tonight, i went to start it, clipped on the DSS key and no beep. Battery dead? Ok hook up the battery charger and i hear a hum coming from inside the ski, sounds like its down at the starter. Clip on the key no double beep, push the start button and get a single long beep.
Does it sound like the starter got stuck? Shorted out?
I took off the positive battery cable and charged the battery. When i touched the cable back to the battery i got a pretty good spark even though everything was off and the key was not on the post.
I was really wanting to finally enjoy them this weekend before its to late.
Any suggestions would be greatly appreciated.
