Hello all,
After reading multiple threads and investigation - I replaced the rectifier. The Issue: At startup (when it would start), the engine would run but internetantly respond to throttle. It felt like it was bogging down. It would never run at correct RPM for more than 5 seconds. I replaced the rectifier, same issue, only this time it wouldn't start at all, just crank.
I disconnected red wire from the rectifier and the engine starts and runs fine. Of course the battery won't charge now. If the rectifier is new, what else could it be? Any comments are appreciated.
Update: Rectifier replaced with OEM. Engine runs fine Out of Water - but in water bogs down on acceloration right at 4500 RPM, stays running but doesn't respond to throttle. let off throttle, try again, same thing, runs strong for 3 - 6 seconds, then bogs down. Also replaced the Relay assembly and checked all fuses in the Grey Front box.
