ya thats crazy, 1 gallon should last you at LEAST 50 gallons of gas at a bare minimum, and thats actually a real conservative number, the last time I wasn't premixed was 2009, but i had a 1 1/4 gallon tank and it took forEVER to run low on Oil, 5-6 long rides, and a good 60-70 gallons of fuel, and then I was just topping it off, it wasn't empty
how much does it smoke when you start it on the trailer ?
are you sure you don't have a ton of oil/buildup, residue in the bottom of the hull ?
and if I may back up before we go forward, is this approximately a Gallon sized tank ? and what is the size of your gas tank.
ie: i'd like to have an idea of actual numbers, gallon of oil = how many gallons of gas...
