96 GSX fuel baffle Removal
Should just slide out. But... on some skis you have to remove the tank.
What's the actual problem?
Hey doc thanx for fast reply....not enough room in hull to slide it all the way out. Have the tank all the way to the front and just trying to get the right angle for the space...hoping i dont have to remove the steering set up:(
Mine was hard to get out, have to pull the tank to the front, undo the fuel lines and it just barely came out. Mine is an spx tho, but still keep trying.
Ooh... And mine already had the upgraded fuel float, put the new one in and still didn't work. hope you have better luck.
On mine I nad to remove the steering and the float assembly came out through the hole. Make sure you chech with an ohm meter to make sure it is working before you put it back.
Got it out but had to remove steering... No way around it. Replaced fuel float and gas gauge worked fine:)
