electroryan
I brought a 951 xp ltd 951. i was stupid not to compression check it . it had low compression.
i stripped the top end. Pistons said 87.91 . people told me can only get 88mm and its the same thing. brought a wsm rebuild kit.
Bore looked clean and no damage. I had a mechanic friend check the tolerances of the pistons ( without rings on ) with a feeler gauge.
put new pistons on and rings and oiled them all up . I used hose clamps to line up rings and slowly slid clamps of when got into the chamfered part of the block. I checked many times to make sure the rings were lined up and that the pins and rings lined up in the right place either side of the exhaust port . you could tell by looking down the exhaust ports.
oiled all components as putting together, slowly turned it over by hand and pistons ran up and down nice. greased gaskets and put all together nicely and torqued up head as per specs.
turned motor over a bit with starter motor running. maybe 6 seconds at a time then waiting a few mins , put bit more oil down spark plug hole. All was going well.
hooked leads up to plugs , proceed to do the run it to bed the rings in .
primed with petrol and just started run on its own spark , then klunking noise and it stalled.
took out power valves and looked down and ring had ripped off and top of pistons missing on both sides.
stripped all back down. metal fragments through reeds and in crank case.
i just dont understand what the hell happened . did the power valves catch on the rings ????
lots of pictures below.
i dont know how to proceed now. please help.
