Spin each of the bearings. They should spin freely and effortlessly. If they bind up at all, or feel rough or "growl" they are bad. Look at the connecting rods. Does it have any writing? or say "WSM" or "SBT"? For a rebuilt crank, especially a 951, I like to go OEM. But i just finished a 951 with all WSM parts (incl crank) from PWC engine. Prices were good, and my buddy has put almost 20 hours on the ski since june. Hasn't missed a beat. The WSM gasket kit seems to hold up well. I like their seals. The paper base gasket is a little flimsy, but so is the OEM kit.
To seal the cases. Get Threebond 1211. Its 18$ a tube, but well worth it. Make sure your gasket surfaces are CLEAN CLEAN CLEAN. Wipe with acetone and let air dry to remove any oil/debris. I've just finished two 951 builds, so let me know if you have any questions. Hardest part is aligning the piston and cylinders. I find locking the crank with a bar and socket on the bench, and a helper make it much easier.
ALSO Do not overlook the counterbalance shaft. Those sealed bearings are prone to failiure and will seize up and bust open your bottom end. I sent mine out to a shop, he used all OEM bearings and seals 70$ for parts, 50$ for labor. Now that I see how it was done, I could have done it myself if I had a shop press.
