951 exhaust?
Don’t bother with the special wrench or trying to make one. With the carbs off it couldn’t be easier.
I personally found it easy with wrench. U only have to loosen the nut. Not remove it
Well i just got the ski last summer i was riding and lost power while in water. Then i noticed i was blowing smoke everywhere,i pulled the seat and noticed i blew the gasket from manifold to pipe. So i bought new and was taking the pipe off to realize the nut wasnt there lol
Also a good time to replace the small 3/32" oil lines when the pipe is off.
I also suggest you make sure you have the updated pipe "diaper" and the rubber deflector flaps installed correctly. If any of that pipe water leaks into the air intake your engine will have a short life.
