951 Engine failure
xr246
Messages
1
Likes
0
Water Crafts
1997 xp
#1
Hey guys.
I have a seadoo 951 engine in my jet boat. I took it out today everything was going great cruising about 5000rpm and then I lost power. I started to head for the shore and the engine cut out completely. I got the boat home and did a compression test and found 30psi on the front cylinder and 0psi on the back. I removed the head and found some bad detonation.
Any ideas as to what has caused this? motor has been in boat for a number of years now and has been great
Thanks
Messages
259
Likes
22
Water Crafts
(2) SeaDoo SPX - 1997 (sold)
SeaDoo Speedster SK - 1999
(2) SeaDoo Spark 90hp - 2016
#2
That one pistons looks pretty bad. Lol and the compression numbers indicate the top end is toast, if those numbers are accurate.
mikidymac
Moderator
Staff member
Moderator
Messages
8,737
Likes
586
Location
California
Water Crafts
2003 GTI
2001 XP
1997 GSX
1996 XP
1996 HX
1996 SPX
01' Superjet
#3
Running lean from dirty carbs and or fuel system.
wolftalk
Messages
11
Likes
0
Location
california
Water Crafts
hx, xp800 and xp limited
#5
on my 951, the pulse/pressure hose that goes to the rave valves cracked where it attached to the bottom of the crankcase. I assume that would let in a bunch of air.
Messages
2
Likes
0
Water Crafts
99 seadoo sportster sk
#6
I had the same thing happen on my 720(single carb). I rebuilt the carb with genuine mikuni kit and was still having lean issues between 2k-4k. After a lot of troubleshooting, checking fuel pump, removing inline fuel filter and rechecking pop off pressure i realize that i had been neglecting one crucial component each time i took my carb apart. i was not checking my accelerator pump. When i bench tested its functions using a vacuum pump i discovered that the accelerator pump output check valve had failed and was not allowing any fuel to pass through during acceleration. Considering you have a duel carb setup and are running lean on both cylinders it would be worth a check. Your accelerator pump is a common denominator because it supplies both of your carbs. When performing an accelerator pump check when connecting your vacuum pump to the inlet side you should hold a vacuum and should not hold pressure and on the outlet side you should hold pressure but not hold a vacuum.
Messages
21
Likes
0
Location
Conroe, TX
Water Crafts
1998 Seadoo GS 720cc
2001 Seadoo XPL 951cc (Will be missed)
#8
As an added note, I would switch to premix and ditch the oil pump. The pump isn’t the problem. It’s the location of the oil tank IMO. I rebuilt a 01 XP and planned on using the oil injection. I purged the system when I got it running and noticed air bubbles in the lines. One look at that and quickly changed my mind. Runs happy ever since. Good piece of mind too.
mikidymac
Moderator
Staff member
Moderator
Messages
8,737
Likes
586
Location
California
Water Crafts
2003 GTI
2001 XP
1997 GSX
1996 XP
1996 HX
1996 SPX
01' Superjet
#9
Actually it isn't and issue on these. Seadoo pumps are extremely reliable and will save you a lot of oil over premixing.
The only thing I have seen go bad on them is a plugged filter from improper maintenance or the little 3/32" oil lines from the pump to the intake breaking from no maintenance. Change the oil filter every couple of years and the oil lines every 5-10 years and they will be fine.
If you have air in the lines you have not purged it enough or correctly. My 2001 XP doesn't have any air bubbles.
Messages
259
Likes
22
Water Crafts
#10
100%. I hate when guys recommend premix on these. Save SO much more oil and the oil injection, like you said, is really reliable.
Messages
21
Likes
0
Location
Conroe, TX
Water Crafts
#11
Maybe the lines to the intake were cracked or like you said, I didn’t purge it enough or correctly. Once I saw that though, I didn’t want to take any chances. I agree that the oil injection system is a great system. My 720 system is flawless to this day.
Adsense
Usergroup
