Jimnut
I recently purchased a 95 XP800 for a price I couldn't pass up. I have had it on the water a few times now trying to troubleshoot why the motor feels as if it has no power at all. Some of the things I have done so far are:
Replaced grey fuel lines
Cleaned carbs and internal filters (everything looked very nice inside)
Cleaned rave valves
replaced wear ring
It behaves pretty good. Will idle just fine but terrible throttle response and it never really feels like it opens up and revs like it should. ( I have a 95 SPX with the 657x engine and it is easily twice as fast and exciting to drive). 3/4 - full throttle is required just to get on plane at any decent pace. Again my 650 SPX will walk all over this thing.
Tonight I removed the water box and then took apart the water regulator and the rubber diaphram was in really bad shape and wasn't sealed at all which effectively rendered it useless. Also noticed that the box had a lot of water in it (few inches deep when you looked down the exit port. I've read up on how the box needs to clear itself out to reach max RPM's and obviously that isn't helping the situation but It doesn't seem like that would cause all of my issue.
I have also done a compression check and the readings are 150 (mag) and 155 (pto). The motor was rebuilt 4 years ago.
Sorry for the long post but I am running out of ideas on what is holding back the RPM's and the power I know this machine is capable of. Any suggestions on what I should check out next?
Sent via Tapatalk
Cleaned rave valves
replaced wear ring
Sent via Tapatalk
