What's the number on the impellor ? Not the pitch number. Look at my avatar, have had this ski since 97 and have done everything possible to it, learned there is no such thing as "pump gas domes" when you have a spec II Factory pipe. Case ported, recut early RV valve blah blah... I had to have the guy who made Fishetti's titanium drive shaft for his XP make me 1, expensive then. I would twist a brand new OEM shaft just from the pump unloading coming out of the water and then reloading under full throttle. When it just has a little runout it doesn't rev, absolutely true and it "zings". If your ski makes power close to what my ski does you will want a Solas "X" prop if all you want to do is short course and drag race, that's what I had until I got the RPM hitting 7800+ then went to a Solas "XO", same series that fits any 785 X4 hull. Your pump the aluminum & brass? Your through hull driveshaft seal assembly the aluminum housing conventional bearing and 2 double lip seals (not the carbon ring bearing). Your hull have the maroon color on the back below rubrail? Oh yeah, stepped seat, the 1 you sit so low your legs get a workout just standing up? These modded will turn so quick and fast it will fling you off, I built the seat up 6 inches so I could hook my leg to keep me and the ski going the same direction. Everyone that tries the go fast and do a squared off corner get's flung off. Jerry Whelchel (Google if you never heard of him) rode it and said fastest accelerating thing he had ever been on. Obviously he has never ridden a full mod current state of the art World tour Seadoo or Yamaha etc. Just getting you ready for the "holy crap" 1st ride. If it doesn't "launch" immediately out of the hole and be 7500 rpm in the distance of the shore to island at Body Beach Havasu case porting and 12-13 lbs pop-off should do it. I'm guessing your NOVI are 46mm, the OEM case ports are around 40 if I remember right so carbs get muted signal, dampened from restriction. OEM case ports are 2 rounded end ovals, mine are shaped like a big bow tie. Oh yeah, and get your squish down to .039 to .043, both sides the same. I can show you how to get your cylinders & domes to be symmetrical, evenly centered so squish is the same on each side of each cylinder, as close as possible at least. Dude, sorry for the term paper, I just know what's ahead for you if you get all the links the same, ride all day just stop and go (go means haul ass). OK, gotta finish loading up for Havasu. Lee
