seadooxp718
Ok si reciently i changed all of my gray gas lines, cleaned out the filters in the carbs they were good though, cleaned the fuel selector out, drained all oil and filled with syn, and replaced all filters. I go to the lake and no bottom end it boggs down hard then slowly climbs and takes off. My high speed is at 0 and low is at 1 3/4. I turned it to a bunch of dirrerent settings but only seams to get worse or stay the same. What else should i check. It idles great and uses just a little gas to start up.
