95 xp bogging down at full throttle
gut-pile
I just rebuilt my 95 xp's carbs and repaced all the gass lines due to the ethanol issue. The machine goes great for about a min. Then bogs down, if I pull the choke it pops right up again. The high speed adjustment specs say it should be at 0 , am I missing something or should I open it up.
Thanks
Tim
With that description... you still have a fuel issue. Be careful... running lean on the top end can melt an engine.
Check the carbs again... verify that the internal filers are clean... make sure you dont' have an air leak anywhere... clean the fuel select valve... make sure the O-ring is good in the water separator.
