here is the story.
i was out jetsking on my 95 seadoo XP, got it up to full speed, when about 2 minutes in, it just stopped like someone pulled the key. no electronics, no starter motor, no gauges, nothing.
got it home. 5 amp fuze was blown( neither of the 2 15s are blowing).
then i noticed that the ground wire had come disconnected from the block. (promptly connected it)
it continued to blow 5 amp fuses the moment you touched the power to the battery.
i still have no gauges, no electronics.
heres what i know.( ive read every forum on this and i still am unsure)
the engine was running fine, now nothing electrical works.
possibility of the mpem being fried due to unstable grounding???
also! if i disconnect the harness to the stator, the popping stops.
it is not the vts motor, (already tried that)
also all the other harnesses are fine, the 5 amp olny pops when the stator harness is connected.( ??is this because that harness has the ground for the electrical box??)
the last thing. i also tested the mpem by disconnecting everything and attaching it dirrectly to the battery, ( red cdi wire to + and black cdi wire to -) and it still pops fuses.
i have done all the testing i have read about.
does this sound like a mpem thing or the stator?? ( im praying it is the mpem, as i would hate to fix the stator.)
if it is a mpem thing, can you fix it?
