KyleW2
I am having an issue with my throttle sticking on my 1995 SP.
I noticed it when reassembling the Seadoo after pulling the carb for rebuild. Throttle wouldn't spring back. Pulled the spring off, seems to have enough strength to spring it back. Pulled both the oil injection cable and throttle cable off the carb and it still doesn't spring back. Pulled the carb off again and the throttle shaft wobbles in and out, and if I push it in (towards the carb), then it gets sticky. If I pull it out (away from the carb), then it seems fine.
What is the answer here? Is this part serviceable or am I looking at a brand new carb? Hopefully that is not the case.
Thanks
Thanks
