It's my second year of owning a 95 GTX 657 Rotax Sea-doo. Last year I had no problem for the whole summer. This year when I de-winterized it, it didn't want to start. When I pressed the starter switch with a fully charged battery, It didn't make any sound (no solenoid sound and no starter sound, just the "click" from the switch it self). That day I removed the battery, opened up the PMEP (I think that's what it's called), check the fuses, they where all good but one was loose so I reinserted-it. Closed Everything up, reinserted the battery and it started. When I insert the key, I can hear the two BIP tone.
Since then, I have replace the oil pump because the old owner converted it to pre-mix and I didn't like that. Change the oil filter, and gas line because they were the grey one. I finished changing everything and when I when to start it, it had the same problem. I hear the two BIP tone, and nothing else when I press on the start switch.
As per usual I read everything on this matter on this forum and I didn't find anything that was my problem. I have watch numerous Youtube video. I am not the most experienced with electrical stuff but I have checked everything that I have read to check online.
I have checked that the 5amp and 15 amp fuse have continuity.
My first thought was a bad starter solenoid, but I have read that when its a bad starter solenoid, I should hear something like a CLICK from the solenoid which I don't hear. To test the solenoid what I did was take a screwdriver and touch the two lead and the starter turn right up. With my multimeter I confirmed that the solenoid received voltage from the battery side and nothing was outputting on the other side when I pressed the start switch.
After that, I checked the starter switch for continuity which everything was fine.
I have read the service manual numerous time and nothing seems to diagnose my problem, I looked at the wiring diagram to try and solve my problem but that didn't work.
What makes me think it's not the starter solenoid, it's that it did the same thing 1 week ago when I de-winterized it like I mentioned above and it ran after giggling the fuses. Is it possible that I have a loose connection somewhere that is causing this issue?
For good measure I ordered a starter solenoid because it's relatively cheap. But I wanted to try my luck here because I know some of you are very experienced with Sea-doo.
Sorry for my atrocious English, it's not my first language.
