Since I am rebuilding the top end of the engine I decided to change the spark plugs along with cables and caps. The problem is that friend of mine disconnected the cables from the coil and did not remember which goes where. I can't find info on which port of the coil goes to which plug
There is pic of the coil attached so if someone can give advice it will be awesome
Thank you
Thank you
