95 GTX Rough Idle Issue
Watson91
Rode it last weekend for the first time. It ran great, but after getting it warmed up when I would bring it down to an idle it would get to running pretty roughly and want to die unless you gave it throttle. I never let it just sit and completely die, but it did get to where it was idling pretty badly.
When throttle was given it never acted like it wanted to bog or die it took right off with no problems, and at any amount of throttle it never had a problem. Not sure if I need to just go through and clean the carb or if there may be another issue with it. Just annoying when you have to constantly feather the throttle to keep it idling okay.
Personally, I would clean the carb(s), but have you tried to just bring up the idle a little, and adjust the low needle??? if it's running OK at mid, and full throttle... it probably just needs a tweak.
