Yes, you will be okay.
I have the exact same machine and was fighting low end bog problems as well. I increased my pop off up to 28ish and have had no problems in two years of running. All other carb parts and specs were left as outlined in the shop manual. I did check my plugs constantly on the first ride after adjusting the pop off and never saw a lean indication. The higher pop off did help improve the low end.
I also had my rv cover milled to tighten up the clearance since there was some wear.
Changing to a 271000400 impeller topped things off. The combination of those three "adjustments" took my xp from being a low end slug to a quick responding machine like I would expect it to be. I have seen conflicting info on impeller pitches, the "sea-doo source" page shows the 94 xp as having an abnormal high pitch compared to othe similar hp machines. Other sources show a more "normal" pitch. I found a pitch gauge on line that I printed on clear plastic and sure enough, my stock impeller was the 16/24 monster. They didn't start using that tall of a pitch until the 96 xp with 110hp, the 94 xp 657x has 80hp........
The impeller change only improved the machine performance. Low end pulls good, top end is around 51 mph. The machine "jumps" at anything under full throttle when I peg the throttle, incredibly strong response to changes. The motor was a full rebuild two years ago.
