What I've done so far..
-Cleaned carbs, pump, selector valve, and replaced fuel lines
-fresh top end
-disconnected the red wire from rectifier, also checked running voltage
That said.. It sounds great running in or out of the water.. If you try to give it some throttle it revs smoothly up to about 4k then refuses to go further. It sounds like spark is cutting out to me. I suspect the cdi/MPEM but can't find a procedure to ohm it out or otherwise test it before throwing another on.
I have had the rotary valve off, but am fairly confident I reset it correctly. Am I missing anything? Suggestions?? It runs and sounds so sweet until you try to rev it past 4000! I'm running out of ideas!
-fresh top end
