stephensimmons
What should my compression be? I checked it and im only showing 70psi on both cylinders. Is that about right? Seems kinda low to me. It cranks and runs and sounds good out the water but have not put it in the water yet.
Yep... I doubt it will start in the water if it's truly at 70 PSI.
This is why we always say to give it a ride before buying. A crap engine can start without a load on it.
But before we jump to conclusions... are we sure the gauge is OK?
Opening the throttle will only give you around 10 psi. So... you would still be in the "Dead" range.
If the crank bearings are OK... slap a set of rings in it, and hope for the best.
Bad crank bearings could cause low comression?
And if this is the problem how much would it cost to rebuild a crank? Or is the gearings something i could replace myself?
Nope... but a new set of rings would cause the crank to explode if it's rotten too.
Very true. Who sells a crank or parts for one?
If you think the bottom half is done... and you are considering a rebuild... just get an engine from SBT. You can't do it yourself any cheaper, and they will give you a one year warranty.
Who is SBT?I fully understand about doing it yourself. But, since you don't save any money... and you really won't have a warranty when you are done... you may as well just get a rebuilt.
But... if you want to do the labor yourself... you can get a reman crank from SBT for about $250.
Sure... the rings could have been stuck, and a short run will free them. Also... it's not good to add oil to the cyl's, because it will give you a false high reading... but you want the internals coated with a "Normal" running amount of oil.
But... with that said... I've never seen a dry cyl jump from 70 to 150 just because it ran for a minute or two.
Me either. Ima get another testet and try it again. I never add oil to the cylinder when testing. I know the engine was dry so we'll see what happens.
