Was just out for a test ride on a somewhat freshly rebuilt ski. Had it seize up on us out on the water. Got it home and started ripping into it and found that we could get it cranking again after it cooled. Noticed an air pocket in the oil inject line so I pulled pump and turned with drill. Can’t get it to pump unless it’s basically past wide open on the throttle. Swapped it out with another one and that one seems to be doing the same. Having the pump lined up with the marks I can’t get it to pump a single drop at 2000 rpm on the drill. Any suggestions out there? Has new filter and XPS 2 stroke oil. Tested the pump completely off the ski by filling the oil line with oil.
