717 winterization question
vogs77
I am going to winterize my friends ski with a 717 in it, 97 GS. Is it ok to just fill it with coolant by gravity feeding it into the supply line from the pump with the engine running. I don't have a pump to fill it but I assume it should fill everything as needed with just a funnel held up high. Is this correct?
Here is what I did, disconnected the supply line and the out line from the back of the ski and held them up high, pinched off the cly lower drain hose after the T for the pisser in the back. Filled with 3/4 gallon of antifreeze while running the ski. Coolant was coming out of the exhaust and the pisser in the back. Does this sound like I got coolant filled everywhere it needs to be?
Always follow Seadoo operation manual winterization procedures. You'll know in the spring. Don't guess
