I changed mine on my 04 RXP. Little to no room. You have to use imagery. Blind work with good socket set. Use a mirror and flash light to get your bearings. You can try to set up some mirrors and a drop lite. It will take some patience. Remove the oil filler cap if it will give you more clearance for your arm. I did remove the fairing under the seat, my year ski has it.
