Hi everyone,
My supercharger gear broken.
I had to move the motor Inside ma garage.
I removed the PTO cover and found the double gear missing teats.
I will change the gear and clean all the oil pump.
Now i what to clean the whole engine.
I got the 2 sea doo locking tool.
I found the TDC of piston 3 and putted the lock tool.
Was able to unscrew the bolt of the gear on the flyweal.
I removed the valve cover, chain tansionner and was able to remove the chain and chain gear from the camshaft
My next step is to remove the block head.
Do i need to lock the camshaft in place before going further on...
The camshaft lock tool don't seams to push in.. only a inche goes in and the tool is 5 inchs long ?
I really what advise as i wont **** my timing
Thanks you !
Thanks you !
