Shagga
G'day I have 2005 3d that was running for about 10 minutes then would drop to idle then stop.wont start for around 15 minutes then is fine for awhile then does it again
Now it only cranks over and won't start. Fuel pump is not running I've pulled it out and it runs straight of the battery. The battery test voltage is fine but I only have 10.45v at the fuel pump plug.Is voltage to low ,fuel pump stuffed or should I be looking else where.
