240 mercury water coming in while running
Others have had this issue here. Some had the gasket fail. Some one had the adapter casting corrode thru.
Either way, you need to pull the engine.
Ebay for some parts. Crowley marine, BamMarine are a couple. Most Merc dealers can get parts. But some have been discontinued by Merc. The dreaded NLA in the catalogs (No Longer Avail.)
You only get water when the engine is running because that is cooling water. Only flows when ... the engine is running. The impeller is your pump.
